ae.sakon Friend
ae.sakon
- August 2017
October 16, 2017 at 8:08 am #1068073When I set Megafilter to show the sub-sub categories.
I had tried to open some articles from the page of the sub-sub categories.
But the result page of ค่ายวัฒนธรรมวิทยาศาสตร์ is go back to the index.
I had checked and then I found the root cause is from the sub-sub categories because…
1)If I set the Megafilter to show Main Categories and sub-categories. The result page is fine.
2)I already created Menus and Categories again. The result page is still go back to the index.Thank you.
Mr.Cat ModeratorMr.Cat
- December 2016
- 53 times in 50 posts
October 17, 2017 at 2:13 am #1068264@ae.sakon
Please asign home menu with an empty article. Then assgin "ห้องการทดลองวิทยาศาสตร์" category to a menu.
The error will gone.
- This reply was modified 7 years, 2 months ago by Mr.Cat.
Wisdom is not a product of schooling but of the lifelong attempt to acquire it.
ae.sakon Friendae.sakon
- August 2017
October 17, 2017 at 5:30 am #1068300Sorry this picture is incorrect.
The problem is in the menu of ค่ายวัฒนธรรมวิทยาศาสตร์.
I had tried to create the Main Menu again and then I had clicked on ค่ายวัฒนธรรมวิทยาศาสตร์.
URL: http://203.156.63.39/jevent2/th/This is the page of ค่ายวัฒนธรรมวิทยาศาสตร์ and then I had clicked on article.
URL: http://203.156.63.39/jevent2/th/ค่ายวัฒนธรรมวิทยาศาสตร์.htmlThe result of the article page is Index Page.
URL: http://203.156.63.39/jevent2/th/176-กิจกรรม/กิจกรรมเสริมกาศึกษา/ค่ายวัฒนธรรมวิทยาศาสตร์/441-ความหลากหลายทางชีวภาพ-ค่าย-๑-วัน.htmlI need your help. Thank you.
1 user says Thank You to ae.sakon for this useful post
- December 2016
October 17, 2017 at 8:28 am #1068325@ae.sakon,
Please follow my previous reply. Just assign category "ค่ายวัฒนธรรมวิทยาศาสตร์" to a menu, the error will gone.
- August 2017
October 18, 2017 at 3:53 am #1068489So…do you have the solution for me?
I need it very much.
Thank you.
- August 2017
October 18, 2017 at 10:24 am #1068586My goodness! I had tried to do that solution. Did you see the menu that I created on the Index?
I had followed your solution but that solution is failed!
And now, you know I can’t change anything if that is corrected categories structures.
I can’t do that, I can’t change the corrected structures of the information.
It’s about the information correctness. You know!?
So… If you know about information is corrected, you need to change? you need to publish the incorrect information?
I’m very disappointed with your answer!
Thank you!
- This reply was modified 7 years, 2 months ago by ae.sakon.
- December 2016
October 18, 2017 at 10:57 am #1068602@ae.sakon,
I’ve assigned this menu to an category. You have to assgin com_content layout instead of jamegafilter layout. http://203.156.63.39/jevent2/th/%E0%B8%84%E0%B9%88%E0%B8%B2%E0%B8%A2%E0%B8%A7%E0%B8%B1%E0%B8%92%E0%B8%99%E0%B8%98%E0%B8%A3%E0%B8%A3%E0%B8%A1%E0%B8%A7%E0%B8%B4%E0%B8%97%E0%B8%A2%E0%B8%B2%E0%B8%A8%E0%B8%B2%E0%B8%AA%E0%B8%95%E0%B8%A3%E0%B9%8C.html
then filter url is correct now
Please check
http://203.156.63.39/jevent2/th/%E0%B8%81%E0%B8%B4%E0%B8%88%E0%B8%81%E0%B8%A3%E0%B8%A3%E0%B8%A1/%E0%B8%81%E0%B8%B4%E0%B8%88%E0%B8%81%E0%B8%A3%E0%B8%A3%E0%B8%A1%E0%B9%80%E0%B8%AA%E0%B8%A3%E0%B8%B4%E0%B8%A1%E0%B8%A8%E0%B8%B6%E0%B8%81%E0%B8%A9%E0%B8%B2/%E0%B8%84%E0%B9%88%E0%B8%B2%E0%B8%A2%E0%B8%A7%E0%B8%B1%E0%B8%92%E0%B8%99%E0%B8%98%E0%B8%A3%E0%B8%A3%E0%B8%A1%E0%B8%A7%E0%B8%B4%E0%B8%97%E0%B8%A2%E0%B8%B2%E0%B8%A8%E0%B8%B2%E0%B8%AA%E0%B8%95%E0%B8%A3%E0%B9%8C.html
- August 2017
October 19, 2017 at 5:05 am #1068722have to assgin com_conten
No, the other categories are in the problem too. I was using another one filter to show my articles but not assign the position for it and keep the Megafilter at the original position then error is gone. It’s not about your solution. Kindly see this!
- August 2017
October 19, 2017 at 5:09 am #1068723Same destination! Why no Error found!
Bye!
- December 2016
October 19, 2017 at 7:03 am #1068750Same destination! Why no Error found!
Because this menu is still active http://203.156.63.39/jevent2/th/%E0%B8%84%E0%B9%88%E0%B8%B2%E0%B8%A2%E0%B8%A7%E0%B8%B1%E0%B8%92%E0%B8%99%E0%B8%98%E0%B8%A3%E0%B8%A3%E0%B8%A1%E0%B8%A7%E0%B8%B4%E0%B8%97%E0%B8%A2%E0%B8%B2%E0%B8%A8%E0%B8%B2%E0%B8%AA%E0%B8%95%E0%B8%A3%E0%B9%8C.html
If you disable it, the error will back. Please, check the attachment below.
AuthorPostsViewing 10 posts - 1 through 10 (of 10 total)This topic contains 9 replies, has 2 voices, and was last updated by Mr.Cat 7 years, 2 months ago.
Hi, I have a problem with Megafilter when I set it to show sub-sub categories.
