edd Friend
edd
- May 2006
- 8 times in 2 posts
April 23, 2008 at 2:51 pm #127835Hi I just installed a new fresh site using the quickstart.
No problems on the installation, no error message, all was fine till I enable Highlight Module.
it works fine, just great, and then I wanted to disable this module and… no way!!!!
I unchecked, I checked, I click on the module and go into the options and click on radio button “enable: no”… and nothing!!!Any idea?
Thanks a lot for help! 🙂
bigrk Friendbigrk
- February 2007
- 45 times in 15 posts
April 23, 2008 at 4:33 pm #246580Did you unpublish it?
edd Friendedd
- May 2006
April 23, 2008 at 7:10 pm #246605Hi there,
well I really dont understand, but if I disable “latest”, “popular”, “youtube” and “media”, the module dissapear, even if it is enabled!!!! so conclusion for me (tell me if I’m wrong): for to disable this module I just need to disable their content and not the Highlight Module
:confused:thanks
Sherlock FriendSherlock
- 2478 times in 2162 posts
April 24, 2008 at 2:59 am #246643Hightslide is default of template, Hightslide module only is mod_custom,
If you want disable Hightslide, you can go to index.php(templates/ja_teline_ii/index.php)
Search those lines(~line 36):
<script language="javascript" type="text/javascript" src="<?php echo $tmpTools->templateurl(); ?>/highslide/swfobject.js"></script>
<script language="javascript" type="text/javascript" src="<?php echo $tmpTools->templateurl(); ?>/highslide/highslide-with-html.js"></script>
Comment or remove them.Sam FriendSam
September 21, 2008 at 11:47 pm #271608<em>@nguoiabcd 50249 wrote:</em><blockquote>Hightslide is default of template, Hightslide module only is mod_custom,
Search those lines(~line 36):<script language="javascript" type="text/javascript" src="<?php echo $tmpTools->templateurl(); ?>/highslide/swfobject.js"></script>
<script language="javascript" type="text/javascript" src="<?php echo $tmpTools->templateurl(); ?>/highslide/highslide-with-html.js"></script>Comment or remove them.</blockquote>
THanks a lot! I have been trying to remove the highslide!
One question:
I would like to use the open/close login from the new Pyrite template, or the old Telline template; how can i do that for Telline II?
September 23, 2008 at 4:09 am #271780<blockquote>I would like to use the open/close login from the new Pyrite template, or the old Telline template; how can i do that for Telline II?</blockquote>
please say more detail, some creenshots are very helpful -
This topic contains 6 replies, has 4 voices, and was last updated by Sherlock 16 years, 3 months ago.
