April 28, 2010 at 4:25 pm #150711
i am trying to use the highslide funtion to make a image gallery, but as soon as i enter the module manager for it.. i lose my control panel. I read on some old post that there could problems with a module table or something.. but i have no idea what they talking about to be sincere.
It not only happens with the highslide.. other modules are given me problems.. mostly the image related.. Some help with these problem as well.. PLEASE.
- 2008 times in 1700 posts
May 2, 2010 at 4:29 pm #342389Hi seob19
in the case, please try to go to database, find job_modules and repair again
May 14, 2010 at 12:59 pm #343611For some who knows reason. every time i try to add anything external to the beryl template, it stop working properly. I had started to work from cero many times already cause these things keep happening. I showed it to a higher up and he said he never saw anything like what happens to me. So i am extremly lucky guy 😉
I am still trying to find a way with it. i am gonna finishe the web page before try to enter any new stuff.
May 24, 2010 at 5:42 pm #344562it really was that everytime i installed highslide.. the thing gave me the headache on the web page.. even if i put to fix the mod.. or the whole page.. it stop working as soon as i installed it
Saguaros ModeratorSaguaros
May 26, 2010 at 2:16 am #344716Did you resolve your issues?can you pls give me the link to your site, if the problems are fixed, because i would like to have a closer look on the issue
May 26, 2010 at 2:38 pm #344802hi
The prolem with that was never solved. Every time i installed the highslide, or anythig.. Almost evrything, gave me problems.
The way i manage to solve it was installing the plugin Boxbot. That worked ok. Didt gave me problems. Is not as funtional as other ones, but worked withiut crashing the web page.If still want to give it a look, the link to the web is the next:
http://www.rrubi-dga.com/vitroColorSaguaros ModeratorSaguaros
May 28, 2010 at 4:18 am #345019Dear seob19!
I saw the site. if you had problems while intalling or using the hightlight plugin. you try to use other plugin named is the popup plugin which supported many modal boxese such as lightbox, fanncy box… http://www.joomlart.com/forums/topic/ja-popup-plugin/
This topic contains 7 replies, has 3 voices, and was last updated by Saguaros 14 years, 4 months ago.
