  • denniskmetz Friend
    #194930
    I am new to T3 and am using JA-Fixel. In the quickstart there is a module position called home-1 yet I do not see it in the template (blocks) anywhere… but this is probably a related question…
    My real question is that I am trying to publish the JA Masshead module into the home-1 position and I cannot see it when I do. However, when I publish the same JA Masshead module into position-1, or other positions, I see it just fine.
    Is there something I need to do to turn this module position on? I copied everything (or so I thought) from the JAFixel quick-start. I am using Joomla 3.2.2 and ja-fixel 1.0.3
    Can you help me please… have been struggling with this issue for several hours.
    Dennis
    Hi Dennis,
    I try to add suffix ?tp=1 into URL to see the module position, for instance:
    http://joomla-templates.joomlart.com/ja_fixel/index.php/en/?tp=1
    http://pasquesi1.taylorbruce.com/?tp=1
    As you can see that there is no home-1 position in your site. In our demo site, we have 2 layouts called: home and default, please make sure that you assign home layout to your homepage: http://prntscr.com/2ttkkl
    denniskmetz Friend
    #523649
    Hello Saguaros,
    I checked and double checked, the template is using the home layout, and is assigned the HOME DECOR menu item which is a JAFixel category, which displays two articles from the category. I have two modules published to the home-1 position, but neither shows up.
    You have my credentials.
    Please help,
    Dennis
    Could you PM me ftp credential of your site? I will check what’s wrong here.
    girlofsparks Friend
    #523929
    I am a new joomla user experiencing the same issue with my on-line site. I am also running Joomla 3.2.2. I did not use quick-start, but rather followed the instructions at http://www.joomlart.com/documentation/joomla-templates/ja-fixel. In the on-line site, home modules are not displayed on pages with either the home layout or default layout. I can also publish the same modules in other non-home positions
    I began my joomla education creating an off-line site on my local machine with 3.2.2 and current fixel. It shows the home modules with no problem.
    I have made the following checks comparing my on-line and off-line sites:
    (1) In templates/ja_fixel/etc/layout/, the default.ini and home.ini files are identical
    (2) In /templates/ja_fixel/tpls/home.php, loadBlock (‘home’) is present in both
    (3) /templates/ja_fixel/tpls/blocks/home.php files is identical
    (4)/templates/ja_fixel/tpls/blocks/mainbody.php files are identical
    girlofsparks Friend
    #523931
    OK Dennis, I think I solved it. The home position is not enabled by default in template manager and this setting is poorly named as Additional Positions. Select Template manager -> Edit Style -> General , scroll down to extended settings Additional Positions. Click cursor in box and select Home 1. Save. Applies for all styles, themes, and layouts. This fixed my on-line site (and was set on my off-line site).
    1. addit_pos
    denniskmetz Friend
    #523934
    girlofsparks,
    THANK YOU very much… that worked for me too…
    As a work around I discovered that a leading article has similar characteristics.
    georgeroth Friend
    #527510
    If I put home 1 there, all the other positions disappear and the home 1 part grows as big as my whole screen. Any ideas?
    Please try to set the grid type for module in home-1 position, check out our documentation for reference: http://www.joomlart.com/documentation/joomla-templates/ja-fixel#extensions-config
This topic contains 9 replies, has 4 voices, and was last updated by  Saguaros 10 years, 9 months ago.
