  • nooran Developer
    #192811
    I’m using JA Magz on my local machine.
    I have changed from the backend template layout the home positions
    Home -10 / Home -11 / Home -12
    to:
    Home -10 / Home -11
    But the problem is that when changed, they became exactly the same width size.
    How is it possible to make :
    Home -10 (25% width)
    Home -11 (75% width) ?
    Many thanks for your help
    You can achieve this by the backend
    Goto your choosen layout then choose the responsive layout tab set the number of modules in Home 1 to 2 ( Home-10 and Home-11 ) and then with your mouse change the dimensions for Home-10 to 2 and for Home-11 to 10
    1. Screenshot_2
    nooran Developer
    #514684
    Worked fine….
    Thanks a lot for your help…
This topic contains 3 replies, has 2 voices, and was last updated by  nooran 10 years, 12 months ago.
