June 5, 2012 at 1:40 pm #177837
I want to change the link to view.
On the homepage there is a layer opens with the article.
If you click on the headline you get to the item view with right module column.
I would like to directly view the item with with right module column.
How do I change the settings link?Regards
cevaJune 5, 2012 at 2:58 pm #456092If I understand you correctly ceva, I believe you want to disable the popup preview? This setting is available via the Template Manager, where you change the popup preview to No!
paucon
HeR0 FriendHeR0
- August 2011
- 588 times in 549 posts
June 7, 2012 at 8:35 am #456445<em>@paucon 323655 wrote:</em><blockquote>If I understand you correctly ceva, I believe you want to disable the popup preview? This setting is available via the Template Manager, where you change the popup preview to No!
paucon</blockquote>
Yes, you are right
Regards,
June 7, 2012 at 9:22 am #456453Template Manager is set to no.
To explain what I mean, see Image Files …
When I click on Home to view the article in the display item.1. initial situation
2. pop-up view
3. item view (my favorite)June 7, 2012 at 9:33 am #456457Short info:
: New installation JALens with sample data
: Error message during installation of Kompomente WidgetKitJTableMenu: : _getNode Failed-…
This is already my 3rd attempt.
What should I do.
Have full access to the database. I’m not a phpMyAdmin professional ;(
See this picture of database.Regards ceva
June 7, 2012 at 9:39 am #456460Sorry, incorrect entry.
HeR0 FriendHeR0
- August 2011
June 7, 2012 at 9:41 am #456461Hi Ceve
Please do step by step as Caupon said, you can look up my attached screenshot.Note: Plese clear all cache after changing the settings.
HeR0 FriendHeR0
- August 2011
June 8, 2012 at 2:08 am #456584Hi Ceve
I understand you and shall try to help you out. I am not sure why your site does not work, please PM me your site url, admin account, i shall check and try to help you out.Regards
AuthorPostsViewing 9 posts - 1 through 9 (of 9 total)This topic contains 9 replies, has 3 voices, and was last updated by HeR0 12 years, 3 months ago.
Home: Articles with links to view item module with column
