billyk Friend
billyk
- January 2006
- 17 times in 1 posts
July 26, 2010 at 9:10 am #152859Hello Joomlart folks…
A much discussed, but never solved problem that I have been having recent issues with is having the HOME button go to the index.php file instead of the index.html file. Yes, I am using a splash page, at my client’s specific request. How do I get it so that when i click the Home button in my Main Menu (currently set up as a Front Page Blog), that it will go to index.php and not just the top level http://www.mydomain.com?
Here’s the site:
http://www.whitemountainyurts.comThanks to the awesome developers here, I turned JA Rasite into a thing of beauty!
billyk Friendbillyk
- January 2006
aaronfarias Friendaaronfarias
- July 2010
- 12 times in 12 posts
July 27, 2010 at 5:53 am #350827It is still linking to the joomla homepage. If you just do a external link to the main directory. it will automatically go to the .html over the .php.
billyk Friendbillyk
- January 2006
July 27, 2010 at 6:52 am #350831you didn’t read my post correctly. i had set up a splash page (index.html), and when i pressed the home button on the JA Rasite template menu, it went to the index.html file INSTEAD of the index.php file. but i fixed that now and it’s all good. hopefully someone who has the same problem can use my tip!
1 user says Thank You to billyk for this useful post
October 25, 2011 at 1:27 pm #421489Using joomla 1.7.0 and ja_purity_ii v1.2.0:
I have the same problem but if I unpublish module Main Menu (which is by default published to position ‘left’) and try to redefine my ‘Home’ button to an external link, i get the error:
Save failed with the following error: The home menu item must be a component.
It seems that regardless of what the Home button’s link is defined as, the template always redirects to ‘mysitename’, which as per your situation, has a flash page displayed by the index.html page which sits in my root directory.
I’ve outlined the problem here:
http://forum.joomla.org/viewtopic.php?f=615&t=668180&p=2652636#p2652636
This topic contains 5 replies, has 3 voices, and was last updated by qubie 13 years, 1 month ago.
