  • obliat Friend
    #172581
    Hi guys, I just noticed my Home (house) icon is not showing up in the menu.
    It has ‘home’ class defined in the Menu settings (magazine) and even if I remove it HOME text does not show up, which means issue’s not there.
    Firebug shows it’s <li> greyed (inactive), but I can’t seem to find out why. Can someone take a look at http://www.ecars.bg and help me out? Looks like a megamenu issue, but may be anything else of course – attaching firebug screenshot.
    Thanks ahead,
    Martin
    1. home-icon
    TomC Moderator
    #433068
    Here is a helpful tool than can assist in investigating issues such as these -> http://www.joomlart.com/forums/topic/use-jas-demo-builder-as-a-learning-tool/
    obliat Friend
    #433082
    Thanks a lot Tom. I do have couple of spare test installations of the same template on my computer to use them in case like this, but that does not help me find a solition. I do have limited knowledge as on top of starting it all from scratch I have to take care of the content daily so I am progressing slowly with my backend skills and oftentimes I need assistance – If I spend hours trying to investigate then there will be no content (which anyway happens from time to time). I will keep trying to find a solution. Thanks again for showing me the tool. I will try it.
    obliat Friend
    #433106
    I was actually hoping to get some help on how this works – the megamenu – and if this might be megamenu related error, or a plugin/component conflict. This is really beyond my knowledge so far!
    TomC Moderator
    #433169
    <em>@obliat 293687 wrote:</em><blockquote>I was actually hoping to get some help on how this works – the megamenu – and if this might be megamenu related error, or a plugin/component conflict. This is really beyond my knowledge so far!</blockquote>
    The reason I suggested using the Demo Builder as a learning/comparison tool is because this seems like it is a “parameter configuration” issue in terms of the “Home” menu item’s configuration. Was the icon displaying at one point when you first started working with the template?
    obliat Friend
    #433173
    Well yes, it’s an (almost) year old website and I love Teline so I’ve learned the specs and customized it – that’s why I said in my first post ‘home’ class is defined and all the stuff. I truly realize what great deal of effors do all the devs put into all these templates and to start a thread it means I spent some time playing with Firebug and my knowledge and browse the forums and only then I start looking for help. I have done no mods to the menu and the only tech admin activity recently is probably related to my JA Comment issue – it wasn’t working again and I opened a ticket, then someone said “well where’s the problem it works”, but it wasn’t working and I think it was fixed. So no mods whatsoever and I’m stuck – but I know how it should be set and yet it disappeared.
    ghjulianu Friend
    #442276
    If it can serve : Go in Parameters (JA Extended) > Additional class : put “home”
    obliat Friend
    #442278
    This is resolved thanks – I had ‘home’ there – it was another issue – devs created additianal Home menu item and fixed it for me. Thanks
    ericl1 Friend
    #463744
    how did you contact the developers of Joomla
This topic contains 9 replies, has 4 voices, and was last updated by  ericl1 12 years, 3 months ago.
