edd Friend
edd
- May 2006
- 8 times in 2 posts
July 6, 2016 at 7:29 am #947205Hi there,
after several months working perfectly fine, now I have this problem:When I’m on a page (nevermind the page) and want to back to the home page and click on the "hme" bouton I get this:
mark(‘afterLoad’) : null; // Instantiate the application. $app = JFactory::getApplication(‘site’); // Execute the application. $app->execute();
in a blank page.
But, if I clik on the logo image I have my home page.
So I have noticed this:
if I write my site using: index.php
I have the message I showed before.But if i add a slash like this: index.php/
How to solve this?
Thanks for help
July 6, 2016 at 10:04 am #947263Hi
Joomla use index.php in the URL , to complete the requests , to check it on your site , could u edit your first post and submit your site temp super user details for staff .edd Friendedd
- May 2006
July 6, 2016 at 12:34 pm #947345This reply has been marked as private.Pankaj Sharma ModeratorPankaj Sharma
July 7, 2016 at 3:02 am #947519Hi @edd
First, assign the template to default Joomla template (protostar) and then check are you getting the same issue on the site . If you it’s same then there is something wrong with the changes u did to remove the index.php from URLs .
here is the tip that helps u how to remove the index.php from URL .Yes if its possible to send the admin details I can check it myself .
July 7, 2016 at 7:58 am #947595This reply has been marked as private.edd Friendedd
- May 2006
September 13, 2016 at 4:19 pm #967968This reply has been marked as private.edd Friendedd
- May 2006
September 15, 2016 at 6:09 am #968389Hi Pankaj Sharma,
I did like you said: Rename the htaccess.txt to .htaccess
and it its not working… I mean, I’m still having the same problem…Any idea?
Thanks 🙂
This topic contains 9 replies, has 2 voices, and was last updated by edd 8 years, 4 months ago.
