August 6, 2013 at 5:05 pm #189523
As you can see on my site at http://whgmag.com, the article postings are not filling in white spaces as they should to look like Pinterest. I have tried re-installing ja_wall as well as the plugins, setting all of the grid and post settings as instructed in the documentation, and the home page still lines up rather than fills in leaving huge white areas.
Please help. I can send you the Administrator login if needed. My client is desperate to make this work.
Web Designer & Social Media Marketer as Words To Web, Inc.
ritalewis@wordstoweb.net | wordstoweb.net | 240-261-4988Nazario A FriendNazario A
- April 2013
- 284 times in 263 posts
August 7, 2013 at 2:27 am #501453Hi ixchup,
I need a closer look to check back-end of your site, you can send me admin login info via PM.
Regards,
Nazario
1 user says Thank You to Nazario A for this useful post
August 7, 2013 at 6:18 pm #501542The page loader is now not working.
- April 2013
August 8, 2013 at 1:40 am #501559Hi ixchup,
Because it conflicts with “Auto Pin It Pro” plugin. Try to disable it, the page loader will work.
Additionally, this is plugin of 3rd party, you can contact with their support team, they will help you more.
Regards,
Nazario
August 8, 2013 at 2:26 pm #501631Any success with figuring out why the layout is screwed up?
ritalewis@wordstoweb.net | wordstoweb.net | 240-261-4988August 8, 2013 at 7:20 pm #501647I solved the problem by removing both Auto Pinterest extensions.
ritalewis@wordstoweb.net | wordstoweb.net | 240-261-4988 -
This topic contains 7 replies, has 2 voices, and was last updated by Nazario A 11 years, 3 months ago.
