  • mcmart Friend
    #903124
    HI
    Different module have access to different LAyout
    How to create a new module with item categories but link to the layout use for the articles ?
    1. art01
    Pankaj Sharma Moderator
    #903167
    i am not able to understand your question . Can u provide some more details what u want to change in the articles category module ?
    mcmart Friend
    #903185
    please check the jpg and tell me if that is clear enough
    thanks for your help
    1. art02
    #903187
    its Joomla articles category module and does not work for K2 items . You need to create a new layout for k2 modules , Its require pretty good knowledge in the css and php . You can use inspect/element or firebug to check the css style . If you are not a developer , i suggest you to hire a developer for this custom work . This is something that is out of support scope .
    mcmart Friend
    #903190
    My worries is more the php side to connect the module k2 to a layout without breaking the template
    the CSS will be the easy part ..
    btw the instead of using firebug i think the best is to upload the file of the layout directly
    but thank again for your time
    i have a last question i try to change the scorecell in the article check jpg thx
    1. art03
    #903227
    You can in the right side the style of the scorcell class . Copy the style in the custom.css and add additonal style with your needs .
    mcmart Friend
    #903233
    sorry i was talking about the number 5 can we have a nb different per article ?
    thx
    #903322
    You can not change it , It comes from the article rating .
    This is limited and comes dynamically when a user rate the article . For more info take a look on this thread for same topic .
This topic contains 7 replies, has 2 voices, and was last updated by  Pankaj Sharma 8 years, 8 months ago.
