  • frankysdc Friend
    #171916
    Hi, I don’t know why, but after some change, now in my homepage don’ta appare nav mod, right mod, ecc… can you hel me.
    In other page all works fine…
    thanks.
    http://www.webtalkitalia.it
    <blockquote>but after some change</blockquote>
    Wich changes exactly ?
    frankysdc Friend
    #430192
    <em>@pavit 289862 wrote:</em><blockquote>Hi
    Thanks</blockquote>
    I’m sorry, I’m working with jatabs settings and menu… but I can’t explain well what appened.
    I have disabled the ja_tabs plugin and the Home seems to be correct
    The problem is in your custom html modules utilizing Ja_Tabs plugin, check all modules and verify 1 at once
    frankysdc Friend
    #430195
    Thanks, the problem, was that jatabs no work in article published into contslide on home page…
    Now, can I ask you how to delet read more in jatabs?
    Thanks again
    You are referring to the contentslider module published on your Home ?
    frankysdc Friend
This topic contains 7 replies, has 2 voices, and was last updated by  frankysdc 12 years, 11 months ago.
