  • mlsuf Friend
    #133039
    Trying to set up a small horizontal menu in the ‘Top’ module position (instead of the vm currency module). Every time I publish it shows as a vertical menu. Are there specific settings that I need? I have tried setting the menu style to ‘Legacy – Flat List’ but with no success. Thanks.
    #269296
    Hi boola0211 !
    you must set menu type to :legacy – Horizontal .
    2754
    mlsuf Friend
    #269986
    Thank you. That works. Where can I find out about styling options for this? I have set the menu class suffix as ‘-nav’. I would like to have a spacer – | between the menu items. I have selected this in other parameters but it is not showing up.
    #270038
    Hi mlsuf !
    please send url of your site and admin acc via pm . i will check it for you !
    mlsuf Friend
    #270058
    Thanks but just solved it – I had messed up the CSS.
    #270509
    Ok mlsuf ! i will mart this thread to “solved”.
    mlsuf Friend
    #270549
    Yes sorry it’s solved.
This topic contains 7 replies, has 2 voices, and was last updated by  mlsuf 16 years, 3 months ago.
