  • oigroig Friend
    #127901
    On my page, mod_ja_catslwi shows only text without picture (see Hot Topic) and mod_ja_slwi shows only a picture without text (see Spotlight). How can I have pictures and text together?
    #246805
    plz pm me an account, I will config help you
    jmef Friend
    #246851
    Hi have the same problem with Hot Topic after quick start installation on Joomla 1.5.2, The whole template shows as in Demo except for the fact that there are no pictures in the back ground at the Hot Topic (mod_ja_catslwi) module.
    The text is as it should be with the correct mouse over response. So assuming you figured out what was wrong oigroig, could you please share the solution?
    I thank you in anticipation!
    vaibhavkavi Friend
    #247348
    i am also having the same problem , please guide me. for time being i disable it from my site
    oigroig Friend
    #247363
    I did not manage to fix the problem with the first release of teline II. I made a clean install of teline II 1.1, and it works now as it should.
    togan Friend
    #247423
    <em>@oigroig 50448 wrote:</em><blockquote>On my page, mod_ja_catslwi shows only text without picture (see Hot Topic) and mod_ja_slwi shows only a picture without text (see Spotlight). How can I have pictures and text together?</blockquote>
    kashxo Friend
    #247454
    There are many reason causing Images don’t show in ja_catslwi (Hot Topic). Please post your site URL here or PM your URL and admin account to nguoiabcd or hainn84 to get your issue fixed.
    Thank you very much.
    jmef Friend
    #247483
    After upgrading from 1.5.2. to Joomla 1.5.3 and installing the latest version of Teline (1.1) al my above problems were resolved!
    togan Friend
    #247497
    Hi All,
    After upgrading from Joomla 1.5.2. to Joomla 1.0.15 and installing the latest version of Teline (1.1) al my above problems were resolved!
    And , fix for joomla 1.0.15 ,
    php_flag display_errors off
    Best Regards
    swhel Friend
    #249964
    Hawe thw problem with no pictures to. http://www.kollon.se
    greengo Friend
    #269024
    Kashxo,
    I am having the same problem at http://www.citiesgogreen.com, but I have unpublished the spotlight module. Looks bad without the pictures. Can you help?
    Much appreciative,
    Sam@citiesgogreen.com
    lcmagaznine Friend
    #307279
    i am having a similar problem. some pictures showing others not. click here http://www.localconnectionsgranada.com/
    to see my problem.
    many thanks in advance
    andy
This topic contains 12 replies, has 9 voices, and was last updated by  lcmagaznine 15 years, 6 months ago.
