  • hooka Friend
    #133979
    I need help making the hot topic module work. I am using the Joomla 1.0 version. It displays the picture – but there isn’t any text showing and it does not slide up.
    You can take a look here: http://dandelionclockrevolutions.com
    hooka Friend
    #273643
    Okay, I have identified a problem with just my homepage it seems.
    if you go to http://dandelionclockrevolutions.com and scroll to the bottom you will the spot light module. It’s not working properly.
    If go to a different page on my site: http://www.dandelionclockrevolutions.com/index.php?option=com_datsogallery&Itemid=488
    It works properly.
    Does anyone have any idea what I could have done wrong?
    Menalto Friend
    #273644
    g oto the module and change the height of it to 100px instead of 200px, the slide up and text is there
    hooka Friend
    #273645
    That did not seem to help.
    Why would it seem to work here: http://www.dandelionclockrevolutions.com/index.php?option=com_datsogallery&Itemid=488
    AND not on my HOMEPAGE?
    Menalto Friend
    #273646
    It looks same on both places to me
    hooka Friend
    #273647
    What browser are you using? i am using IE6. Does it work on either page or not?
    Menalto Friend
    #273648
    Did you change the height as i suggested above?
    hooka Friend
    #273650
    Yes. But what I am telling you is that the module works just fine when you click on my gallery page.
    It just does not work on the homepage for some reason
    Menalto Friend
    #273652
    It works here in FF, and IE6. But its set to height is to much.
    hooka Friend
    #273653
    Alright – I am not concerned about the height so much as to why the slide is not working.
    I hate to be a pain in the ass, but could you go to http//dandelionclockrevolutions.com and screenshot the spotlight module for me? I just want to see what you are seeing.
    Menalto Friend
    #273654
    This is what i see in IE6 and FF:
    hooka Friend
    #273658
    wow, I am so confused as to why it does not work on my computer now.
    Thanks for posting that up.
    Menalto Friend
    #273659
    As i said in first post it works, but you need to adjust the height
This topic contains 13 replies, has 2 voices, and was last updated by  Menalto 16 years, 3 months ago.
