  • winniekrapp Friend
    #131783
    I’ve written an article with two images inside. Unfortunetly ‘mod_ja_catslwi’ displays in hot topic the second image of my article. Are there some specific criterias to do this and a way to configure correctly its work?
    Thank you!!!
    Bruno
    #263823
    Hi winniekrapp !
    Do you want to display first image ?
    winniekrapp Friend
    #263846
    Yes, thanks! How can i do this?
    winniekrapp Friend
    #264040
    Help me, please! :confused:
    #264069
    Hi winniekrapp !
    you can get first image following way below :
    Open helper.php file in modulesmod_ja_catslwi folder , find following code section :
    function replaceImage( &$row, $autoresize, $maxchars, $width = 0, $height = 0 ) {
    global $database, $_MAMBOTS, $current_charset;
    $image = "";
    $regex = "/<img.+srcs*=s*"([^"]*)"[^>]*>/";
    preg_match ($regex, $row->text, $matches);
    $images = (count($matches)) ? $matches : array();
    if (count($images)) $image = $images[1];
    if ($image) {
    if ($autoresize && function_exists('imagecreatetruecolor')
    && ($image1 = modJaSLWI::processImage ( $image, $width, $height ))) {
    $image = 'background:url('.JURI::base().$image1.') no-repeat;';
    } else {
    $image = 'background:url('.JURI::base().$image.') no-repeat;';
    } else $image = '';
    $regex1 = "/<img.*/>/";
    $row->introtext = preg_replace( $regex1, '', $row->introtext );
    $row->introtext = trim($row->introtext);
    $row->introtext1 = strip_tags($row->introtext);
    if ($maxchars && strlen ($row->introtext) > $maxchars) {
    $row->introtext1 = substr ($row->introtext1, 0, $maxchars) . "...";
    // clean up globals
    return $image;
    change to :
    function replaceImage($row, $autoresize, $maxchars, $width = 0, $height = 0)
    $text = $row->introtext.$row->fulltext;
    preg_match ($regex, $text, $matches);
    $tmpAr = array(1);
    $result = array();
    while (count($tmpAr) && $matches[0]) {
    $result = $matches;
    if (@$matches[0] == '') break;
    $tmpAr = explode($matches[1],$matches[0]);
    $text = $tmpAr[0];
    $image = (count($result)) ? $result[1] : array();
    return $image;
    #264074
    You can downloas Patch for fix this issue below :
    winniekrapp Friend
    #264091
    Thank You Hainn84 for your precious help.
    Jason McDaniel Friend
    #285979
    The autoresize isn’t working for me with the patch. All my images are original size and then cropped in the hot topic box.
This topic contains 8 replies, has 3 voices, and was last updated by  Jason McDaniel 15 years, 11 months ago.
