  • ccvpguy Friend
    #140915
    Hello all;
    My hot topic is not showing any images, it shows only green text (see attachement)
    I am currently using JA Teline II 1.5.10.
    Background Info:
    I planned to run Joomla security update, but mistakenly I downloaded Full Joomla Package 1.5.10 and extracted which installed latest Joomla package! (Before I performed this update I was using JA Teline II 1.5.9 ver 1.6). (I did backup by using Joomlapack, but don’t know how to restore it, need to spend little bit of time)
    I almost got an HEART ATTACK, because I thought this will mess up my site which is ready for deployment, but everything seemed working fine. 🙂
    I decided to make the site ready for deployment and I disabled anything that wasn’t completed and that included the hot topic…. I cleared the cache as well
    Then while double checking to make sure that everything is ok, I enabled the hot topic and some other stuff to see the different look and feel of the site when hot topic is up and when is missing!! I viewed the site and all I saw was hot topic Title, no image or Text!. I tried to figure out what went wrong but couldn’t come up anything!!
    I decided to uninstall the extension (mod_ja_catslwi.zip) and reinstall it. I performed this process couple of times by using mod_ja_catslwi.zip extension from JA Teline II1.5.9 and JA Teline II 1.5.10. But I all get is green text with no images, also the information on the NEWS (Hot topic Links) has changed!.
    After all these; I decided to download the quickstart from Joomlart and I extracted JA Teline II 1.5.10 and installed on top of my existing folder successfully in the hope that this will bring back my favorite hot topic 🙂 ( I did backup)… still getting green text with no images
    Also, mod_ja_catslwi Parameters has changed, specially setting up image Size ..etc. Please see my attachment Hottopic-backend and compare the JA Teline II – Userguide http://www.joomlart.com/forums/topic/ja-teline-ii-userguide/
    2.3. JA Category Spotlight with Image (mod_ja_catslwi.zip)
    [position: left]
    I searched the forum and saw that Cornelio posted a detailed info about existing hot topic problem >> see Post #8 on this LINK
    http://www.joomlart.com/forums/topic/all-templates-updated-to-joomla-1-5-10-bug-fixes-for-official-ie8/
    The only option I am thinking is to try and add some images to my current Hot topic and see how it behaves. Other than that I hope the Admin/Mod will notice this problem and provide quick solution.
    All I need is to have a hot topic that shows as the JA Teliine II Demo.
    Ps, I would like to thank Cornelio who provided detailed info about the Hot Topic problem.
    I learned a lot since I joined this forum and I would like to thank those who go extra mile and try to assist the rest of the community
    Sorry, I don’t have live site yet
    1. hotspot
    2. hottopic-backend
    ccvpguy Friend
    #303862
    Problem solved… I restored my back up using joomlapack >> http://www.joomlapack.net/
    Next step is to install Joomla Security update, but i am not sure where to extract it….:-(
    Even though i am newbie, i think JA needs to fix mod_jacatslwi to much the demo and the user guide
    After the back Hot topic/mod_jacatslwi shows spacing problem, but i can fix that, thanks to phill luckhurst http://www.joomlart.com/forums/showthread.php?p=113801#post113801
This topic contains 2 replies, has 1 voice, and was last updated by  ccvpguy 15 years, 7 months ago.
