  • sclb Friend
    #183701
    The above post was answered and closed on how to fix this with CSS, but what about fixing it via LESS? Thanks.
    we2solutions Friend
    #478594
    I think you miss the post link.can you re post it to see.
    sclb Friend
    #478601
    Not sure what you mean, I had asked how to fix the white hover color using LESS instead of CSS.
    we2solutions Friend
    #478606
    “The above post was answered and closed ”
    I am unsure about that.it didn’t clear to me..
    sclb Friend
    #478608
    Sorry, let me clarify.
    The other post here pointed out an issue with a white hover color on light style on the navigation.
    Instructions were posted how to fix it via css but this change is overwritten when using LESS.
    Can you please explain to all of us that face this issue how to fix the white hover color on the light style using LESS?
    we2solutions Friend
    #478621
    Add opacity to relevant css..i am not total clear about your question.
    Eg:opacity:0.5;
    Use this links as ref.
    http://webdesign.about.com/od/css3/a/aa121306.htm
    http://www.w3schools.com/css/css_image_transparency.asp
    reslinkdomain Friend
    #494742
    Yes – I have been thinking the same thing: Why LESS exists? 🙂
    You can see more info here: http://lesscss.org/ , Less brings out benefit and it’s so great :): spend less time coding and building interfaces
This topic contains 8 replies, has 4 voices, and was last updated by  Saguaros 11 years, 7 months ago.
