June 4, 2009 at 6:10 pm #141697
How can I add a module above body and right column, next to left column. I attached position of the picture. 5268. I can add above the left column and body. But i want to put module above the right column and body. Need help plz
theprofessor Friendtheprofessor
- March 2009
- 64 times in 18 posts
June 4, 2009 at 6:33 pm #306949Go to joomla.org and search the forums for ‘create new module position’ or something to that effect.
You will find a ton of threads, like this one: http://forum.joomla.org/viewtopic.php?f=480&t=206206&hilit=create+new+module+position … about this same topic, and should easily find your answer.
Good luck! 🙂
1 user says Thank You to theprofessor for this useful post
AuthorPostsViewing 2 posts - 1 through 2 (of 2 total)This topic contains 2 replies, has 2 voices, and was last updated by theprofessor 15 years, 3 months ago.
How can I add a module above body and right column?
