test melih
 melih
  • jukeboxjunkey Friend
    #149579
    Ok, there’s probably a simple answer, but for the life of me I can’ t see how to change the ja-main, and ja-right widths. Any help would be appreciated. 🙂 Thanks!
    vitormarques Friend
    #336652
    Hello jukeboxjunkey
    Well that can be solved.. but I must warn you to be very careful with these changes.
    Please backup template before doing any of these changes.
    So let’s begin with changing ja-main width:
    01. Open “main.php” in “templates/ja_urani/layouts/blocks/”
    02. (Line 2) comment that line this way: <!– <div id=”ja-main” style=”width:<?php //echo $this->getColumnWidth(‘mw’) ?>%”> –>
    03. (Line 3) add this line: <div id=”ja-main”>
    04. Alternative to number 03: <div id=”ja-main” style=”width: INSERT WIDTH HERE “>
    05. Save.
    Changing ja-right:
    01. Open “right.php” in “templates/ja_urani/layouts/blocks/”
    02. (Line 3) comment that line this way: <!– <div id=”ja-right” class=”column sidebar” style=”width:<?php //echo $r ?>%”> –>
    03. (Line 4) add this line: <div id=”ja-right” class=”column sidebar”>
    04. Alternative to number 03: <div id=”ja-right” class=”column sidebar” style=”width: INSERT WIDTH HERE “>
    05. Save.
    Then you should add width by css files.
    I hope this helps you. If you have the same problem in ja-left, repeat the same steps but in file “left.php”.
    Let me just warn you again that you are modifying files from template… so please do a backup and everytime you make a modification you should see how the template reacts.
    If you have any more doubts or problems please contact me and I’ll help you.
    Best regards.
    #336691
    Hey thanks so much for the tip. It worked, but not 100%.
    Using Firebug i find <div id= “ja-mainbody” style=”width: 52%;”> is over riding and preventing the ja-main width from displaying the required width. How does “ja-mainbody” determine a width value?
    In Firebug’s “style” column, it is displayed as element.style { width:52%;}
    For the life of me, i can’t find where to edit this value.
    #336692
    Ok, with your help I was able to resolve.
    I made the changes you indicated and added the following:
    01. Open templates/ja_urani/layouts/default.php
    02. Commented out line 71 ‘<div id=”ja-mainbody” style=”width:<?php echo $this->getColumnWidth(‘mw’) ?>%”>’
    03. Inserted into line 72 ‘<div id=”ja-mainbody” style=”width:550px”>’ (The width that I required)
    In addition, you can adjust and fine tune the margins within layout.css
    vitormarques Friend
    #336760
    So in the end is everything as you want?
    #341856
    Actually, not the best result. i would prefer to be able to control the column widths by %.
    #341962
    Ok, I’ve found the RIGHT solution thanks to the Joomlart awesome support staff. Thanks for your help by the way!
    ***** Support Response **************************************
    In this case you can try as follows open templates/ja_urani/layouts/default.php file you will see this line of codes
    $this->_basewidth = 24;
    change it to
    $this->_basewidth = 21.5;
This topic contains 7 replies, has 2 voices, and was last updated by  jukeboxjunkey 14 years, 9 months ago.
