  • ssjn Friend
    #117162
    hi
    I need to change the body background to white, the body is where the content are the problem is the im using virtualmart and all the pictures then i have,has white background and look wear with the original background.
    Thanks 🙂
    Hung Dinh Friend
    #210436
    You can change the following styles in template_css.css file
    body#bd {
    text-align: center;
    background: #475573;
    color: #FFFFFF;
    ssjn Friend
    #210514
    Thanks for the answer but the problem then i have is the all the pictures then i have on the shopping cart have white background and inside the website where the content is have another color not white and looks wear i need to change that.
    Thanks a lot!!
This topic contains 3 replies, has 2 voices, and was last updated by  ssjn 18 years, 4 months ago.
