puntje Friend
puntje
- April 2014
- 4 times in 3 posts
July 9, 2015 at 11:19 am #208459How do i get my footer menu in active mode in another color
It stays in the same color as not active mode.
Also a question modules how will be read by robots. Because it not page connent. I was thinking about that. Because it also important seo. So like the tags. Can some give me more information about that. What is the best way to put the tags in.
jooservices Friendjooservices
- October 2014
- 1245 times in 1121 posts
July 9, 2015 at 11:28 am #576832Hi there
There are .active class here. Please use it with your own custom cssThank you,
Viet Vupuntje Friendpuntje
- April 2014
July 9, 2015 at 11:31 am #576833I did this
#ja-footer a:hover,
#ja-footer a:active,
#ja-footer a:focus {
color: #0000ff
}If i do this:
#ja-footer a:active
color: #ff0000
}#ja-footer a:hover,
color: #0000ff
}But it will not stay for example the red color for active, it wil get the hover color. With my other website i have the correct css for active. But it did not work in this case.
- October 2014
July 9, 2015 at 11:33 am #576834Hi there
Please try
#ja-footer .ja-fn .t3-footnav ul.nav li.active {color:red}
puntje Friendpuntje
- April 2014
July 9, 2015 at 11:43 am #576840Does not work with my template the above code. The button will not stay active.
I tried to put in:
#ja-footer .ja-fn .t3-footnav ul.nav li.hover {color:#fff000;}
#ja-footer .ja-fn .t3-footnav ul.nav li.focus {color:#fff000;}
#ja-footer .ja-fn .t3-footnav ul.nav li.active {color:#ff0000;}Also #ja-footer .ja-fn .t3-footnav ul.nav li.active {color:red} But is does not work.
A takes the css from the template css:
#ja-footer a:hover,
color: #0000ff /*in template css it orange hover, so with the #ja-footer .ja-fn .t3-footnav ul.nav li.active {color:#ff0000;} it gets orange*/
}jooservices Friendjooservices
- October 2014
July 10, 2015 at 1:40 am #576887Hi there
Please provide your site backend & CPanel access. I’ll help you work on it.Thank you,
Viet Vujooservices Friendjooservices
- October 2014
July 12, 2015 at 10:06 am #577068Hi there
I can’t access your site backend. Please check it at your side ?<blockquote>Productfotografie Tilburg – Bij ons staat samenwerking en kwaliteit op plek 1!
Warning
You do not have access to the Administrator section of this site.</blockquote>Thank you,
Viet Vu -
This topic contains 7 replies, has 2 voices, and was last updated by jooservices 9 years, 4 months ago.
