  • Tech-xml Friend
    #202190
    How do I publish a menu module in position right-menu. So it functions like the menus on the left.
    TomC Moderator
    #553410
    <em>@insofticursos 450636 wrote:</em><blockquote>How do I publish a menu module in position right-menu. So it functions like the menus on the left.</blockquote>
    You simply do just that . . . publish a menu module within a right position.
    Tech-xml Friend
    #553420
    I tried this. However the menus are not rendered correctly as shown in the attachment.
    Has some calsse or suffix should I use to fix?
    1. menu-config
    2. Menu
    TomC Moderator
    #553426
    How are they supposed to render? Do you have a menu published to left on your site?
    If so, it would be helpful if you could provide the url of the site you’re working on.
    Tech-xml Friend
    #553429
    The site is offline
    where do I send the data access?
    TomC Moderator
    #553430
    Well, unless your site is online to view, I can’t really determine the differences and try to figure out a possible solution for you. Are you not able to upload your site to your webhost server – and then send me the url info via private message?
    Tech-xml Friend
    #553439
    Resolved – The problem was the menu level
    Tech-xml Friend
    #553456
    Issue arose with the same menu
    I set the menu and access the module to “Guest”. However the menu does not appear for ordinary visitors.
    Tech-xml Friend
    #553621
    Any solution?
    Eragon H Friend
    #553688
    You should check the Access Level of “Guest”, or just set the module access to “Public”
    http://prntscr.com/4y7fzz
    http://prntscr.com/4y7g3c
This topic contains 10 replies, has 3 voices, and was last updated by  Eragon H 10 years, 2 months ago.
