  • mj1256 Friend
    #121162
    I am using the ja-teline. template. I want to use it on a site using community builder so i have a frontend and a backend.
    I want to use the masscol + 2 columns layout for the front page
    and the 1 right cols for the logged in back end pages
    how do i do this
    mj1256 Friend
    #223079
    does anyone have any answers on how to split the layout between sections?
    ErikThorsen Friend
    #223142
    I think you would have to “create” 2 versions of the template and set one of them up with a 1 col layout. That would solve your issue. It would not be possible to use the same template with the different “options” of cols without creating a new and modified version first I am afraid.
    mj1256 Friend
    #223171
    thanks for the responce
    if i just don’t publish anything to the module positions, will the second column colapse with nothing published to it?
    I got everything else to work just fine, the template is awesome
    I was originally thinging the same proccess you suggested, it would be the easiest and most consistant, i have never been able to figure out how to have two versions of the same template on joomla
    anyone have the steps to do that?
This topic contains 4 replies, has 2 voices, and was last updated by  mj1256 17 years, 5 months ago.
