  • 2Patrick Friend
    #133060
    I am using Nerine Quickstart with J1.56 in a localhost
    I want to know how come the articles that are published to the Frontpage Manger does not appear in the Frontpage ?
    I unpublished all the sample modules that appeared ( Special Offer, Testimonials etc )
    I then published some of the other articles in Quickstart eg “GE, Abbott nix proposed $8B deal” etc as to appear on Frontpage Manger but they still dont appear .
    Please clarify .Thanks
    Menalto Friend
    #269177
    Can you post a screenshot of the articles manager?
    abalogun Friend
    #274313
    <em>@2Patrick 78213 wrote:</em><blockquote>I am using Nerine Quickstart with J1.56 in a localhost
    Please clarify .Thanks</blockquote>
    I experienced the same problem. To get round this, I created an article/page using the Module manager – Custom HTML and set the position to User1
    transformations Friend
    #289410
    I am having this problem too, has anyone sorted it out, so that we can just tick the publish in front page button?
    Thanks.
    #289414
    Hi, sorry forget it I found the solution, although I had to tamper with index.php as advised.
    chadpatcharena Friend
    #292898
    <em>@transformations 109715 wrote:</em><blockquote>Hi, sorry forget it I found the solution, although I had to tamper with index.php as advised.</blockquote>
    Can you share the changes you made to make this work? I’m also trying to figure out how to get articles to show up on the frontpage. Thx.
This topic contains 6 replies, has 5 voices, and was last updated by  chadpatcharena 15 years, 10 months ago.
