Viewing 15 posts - 1 through 15 (of 23 total)
  • seaneo Friend
    #181597
    at: 173.254.15.37/next/
    if you scroll down to about article 26 on the wall, you will see a image that says “Support Joomla”
    How can I hide the title and intro text?
    I already changed the options in “Article Options” to:
    Show Title : HIDE
    Show intro text: HIDE
    but they still show up,
    seaneo Friend
    #470797
    Hello, any response please?
    HeR0 Friend
    #470829
    Hi Seaneo
    PM me url, admin account. I need check direct this article.
    Regards,
    HeR0 Friend
    #470923
    I edited title and description of that article . Please check again. The problem is that the article has the title is Title – Support Joomla and fulltext is introtext: Support Joomla
    Regards,
    seaneo Friend
    #470997
    Hi HeRo, for sure a mis understanding, because the “Support Joomla” title and “Support Joomla” intro text are still there. I need to hide them both, so that the user sees only the image in this particular article when it appears on the front page of the WALL. Please advise – thanks
    HeR0 Friend
    #471030
    Hi Seaneo
    That setting only applies for article detail page while you are mentioning to category blog page. So i am sure that your idea is impossible, sorry.
    Regards,
    seaneo Friend
    #471091
    That is a shame! if the article title and text are optional to show or not, why doesn’t Joomla just make it available no matter where the article is being displayed?
    What about this? I reduced the article text to one letter (x) and made it color white, so now in the article human eyes cant see it, but you can still see the x in the category blog view on the front page of WALL. No way around this either? thanks in advance
    arucardx Friend
    #471124
    What you want could be done in K2.
    Alternatively, you can also create a css style like say image-only then set the text all to display:none then use that style in the extended class to achieve the same effect =) But one problem with this is that the category link is still visible in the source code, so you will need to disable link on category title.
    seaneo Friend
    #471134
    well you already have me previously convinced not to K2 my site for now, given the lack of support from the K2 folks at the moment..
    The css style concept sounds fantastic and I see no problem with a category code visible in the source code, the key is,in selected cases. just for the image to show to the human eye with no words appearing below
    What could be the coding or methodology for this css style? thanks
    arucardx Friend
    #471155
    Take a look at the style item-sticky. It provides a very nice example on how to hide unwanted stuff.
    seaneo Friend
    #471182
    Will this affect all the articles or will I have the ability to just change one, like I am trying to do?
    Do you have a link to the sticky? I only see two sticky’s and neither of them relate to this that I see, thanks
    seaneo Friend
    #471302
    Thanks Arucardx, do you have a link to that style sticky? I looked through the JA WALL threads but could not find it – thanks
    HeR0 Friend
    #471328
    Hi Seaneo
    You need small customization in template.css
    Example : edit that article and add class no-content as image http://easycaptures.com/fs/uploaded/702/9840139747.png . Open template.css file and add #masonry-container .no-content .item-main { display: none; } . Hope that can help you.
    Regards,
    seaneo Friend
    #471375
    Thanks HeRo,
    Where in the template.css do I add that line ?
    HeR0 Friend
    #471384
    <em>@seaneo 344077 wrote:</em><blockquote>Thanks HeRo,
    #masonry-container .no-content .item-main { display: none; }</blockquote> Please add to end of template.css file
    Regards,
This topic contains 23 replies, has 4 voices, and was last updated by  mackdoyle 11 years, 7 months ago.
