test melih
 melih
  • crismary01 Friend
    #137416
    I’m using JA Galena template, and I would like to know how to add a banner on the upper right hand side where ‘search’ module is located, basically I don’t need search on the uppper right hand side of template.
    Appreciate your help
    Cristobal
    crismary01 Friend
    #292705
    I’ve been waiting for reply for too long now, is any moderator looking at the new questions????
    scotty Friend
    #292729
    Yes the moderators are busy giving support. This is not a support question it is a customisation request.
    There are several threads on the forum with instructions on how to add and modify module positions (and 000’s on google).
    If you don’t plan on using the search box then publish your banner to that position (User4) and adjust your CSS to suit your banner size.
    template_css.css (line 1072)
    #ja-search {
    background:transparent url(../images/icon-search.png) no-repeat scroll left center;
    font-size:11px;
    padding-left:28px;
    position:absolute;
    right:20px;
    top:40px;
This topic contains 3 replies, has 2 voices, and was last updated by  scotty 15 years, 11 months ago.
