  • mrcasmir Friend
    #196511
    Pls how do I add a module position to the Right side on the Main Nav to look like the SectionNav or SideNav. See attached picture.
    1. Capture
    chavan Friend
    mrcasmir Friend
    #529849
    Thanks for your speedy reply but I have tried that tutorial but still can’t create a position there. I would appreciate your input or anyone else’s. I just I just need to know which files to edit. I edited the header.php but it didn’t work.
    chavan Friend
    #529894
    no you need to work on templatesja_magztplsblocksmainnav.php
This topic contains 4 replies, has 2 voices, and was last updated by  chavan 10 years, 7 months ago.
