  • scilla Friend
    #173858
    I am using joomla 1.7 with JA Nex. I need to add another column(position) between the content and right position.
    Anyone wiling to help?
    Thank you in advance!
    Regards,
    Scilla
    From your template manager — Ja_Nex_Default — Layout tab — Default layout — Edit, in the middle block section
    <block name="inset2">left</block>
    <block name="right2">right2</block>
    <block name="right1">right</block>
    add the block in RED
    then in your templatesJa_NextemplateDetails.xml add this
    <position>right2</position>
    Save the file and clean your JaT3 cache
    scilla Friend
    #438217
    It works! Thank you!
    Next question is how to make it smaller? I mean in width?
    Thank you !
    Scilla
    You need to set the width … look at this guide
    scilla Friend
    #438222
    Thank you! I will.
    Scilla
This topic contains 5 replies, has 2 voices, and was last updated by  scilla 12 years, 11 months ago.
