  • melanieb Friend
    #188017
    I want the background of my site to be white. I have changed this in the template.css. Howver I now need to add a border around the main sheet or content block to separate the background from the main body.
    I am not sure what the ‘main body’ block is called as have tried adding a border to body and body.bd but nothing changes so assuming its called something else.
    Can anyone point me to the right css name?
    TomC Moderator
    #494889
    So that I can try to best assist you, please provide the url of the site you’re working on,
    as well as set “Optimize CSS” to “No” within your Template Manager–General settings
    melanieb Friend
    #494902
    Hi Tom,
    does this image help:
    I have made my background white but it now blends in with the main content area so i just want to add a border
    1. exampleborder
    TomC Moderator
    #494905
    It helps . . . . but can you provide the url of the site you’re working on, as well as set “Optimize CSS” to “No” within your Template Manager–General settings ??
    melanieb Friend
    #494918
    Hi tom,
    I have sent you the link privately as site is still under construction and also set the optimise css to no
    Many thanks
    TomC Moderator
    #494923
    You are going to need to modify several different CSS rules with “border” properties to achive the effect you’re going for.
    The good news is, all of the rules are within the same CSS file. 😎
    START WITH . . . .
    Within file path –> /templates/ja_mendozite/css/template.css
    at line 970, add additional border properties to this CSS rule – as follows:
    #ja-topsl .main {
    border-left: 1px solid #E5E5E5
    border-right: 1px solid #E5E5E5
    padding: 0;
    Likewise . . . .
    at line 827, add additional border properties to this CSS rule – as follows:
    #ja-container .main {
    padding: 20px 0 0;
    Likewise . . . .
    at line 1109, add additional border properties to this CSS rule – as follows:
    #ja-botsl .main {
    border-top: 1px solid #E5E5E5
    padding: 0;
    NOTE:
    For the last part, you may want to delete the “border-top” property to give the whole thing a better “flow”
    … unless of course you like the border/separation look.
    Let me know if this achieves the kind of result you were looking for.
    melanieb Friend
    #494997
    Hi Tom,
    thank you so much – that is exactly what I wanted – perfect.
    TomC Moderator
    #495036
    Glad to be of assistance . . . All the best with your continuing site development !!!
This topic contains 8 replies, has 2 voices, and was last updated by  TomC 11 years, 5 months ago.
