  • breathwork Friend
    #176918
    I need to be able to add some code into the head block of each page on the site, its a script from torbit. How can I do this? ie; which files should I edit?
    TomC Moderator
    #452426
    <em>@breathwork 318922 wrote:</em><blockquote>I need to be able to add some code into the head block of each page on the site, its a script from torbit. How can I do this? ie; which files should I edit?
    Thanks</blockquote>
    When you say you want to add code to the “head” block – do you mean the “Header” BLOCK position itself – or are you trying to add some code within the <head></head> tags?
    breathwork Friend
    #452453
    Between the head tags
    breathwork Friend
    #453151
    bump please
    chavan Friend
    #453246
    There are many ways to add code block in head tag. Such as:
    1/ Copy file plugins/system/jat3/jat3/base-themes/default/blocks/css.php to templates/<ja template>/blocks and add block code in the end of the copied file.
    2/ Copy file plugins/system/jat3/jat3/base-themes/default/page/default.php to templates/<ja template>/page and add block code into head tag in copied file.
This topic contains 5 replies, has 3 voices, and was last updated by  chavan 12 years, 7 months ago.
