test melih
 melih
  • ithacaindy Friend
    #173983
    I want to add code for the Meebo bar between the <body> and </body> tags. Which file do I edit? Thanks.
    Goto this file pluginssystemjat3jat3base-themesdefaultpagedefault.php and edit the file to insert your code
    As this is a t3 plugin file related, every time you update the plugin you will loose your modifications, so you need to create a new folder named page in your templates folder, then copy the file default.php from the path i mentioned above and past it in your page folder and make your customization in that file, so everytime you will update your plugin you don’t loose your customizations.
This topic contains 2 replies, has 2 voices, and was last updated by  pavit 12 years, 11 months ago.
