  • jopi777 Friend
    #163060
    Hello, I guess the headline of this thread tells it all. However here is an image attached to illustrate what I need. The module position at top of the content…
    1. joomlart
    khoand Friend
    #387532
    – Edit default layout (login backend–>goto Extensions–>Template manager–>your template–>layout tab–> default layout), add this code
    <block name="content-mass-top" type="modules">content-mass-top</block>
    into
    <blocks name="middle" colwidth="22">
    – Set position of module is content-mass-top
    jopi777 Friend
    #387555
    Well I tried it and it’s not working. Now my code in the middle looks like this:
    <blocks name="middle" colwidth="35">
    <block name="inset1" width="18">left</block>
    <block name="right1">right</block>
    </blocks>
    And I added “content-mass-top” position into templatedetails.xml
    The module now goes at the top of left block and middle block, and I want it to go just on the top of middle block.
    What do you think why its not working? Anything I missed to do?
    khoand Friend
    #387670
    Sorry about my mistake. Use this code (without type=”modules”)
    <block name="content-mass-top">content-mass-top</block>
    jopi777 Friend
    #387679
    I’m not sure why, but its still going over the top of my left colon? Cant believe that it’s such a pain only to add module position… I guess this should be built into framework..
    Do you have any other advice for me please?
    khoand Friend
    #387682
    Could you give me username+password of your website?
This topic contains 6 replies, has 2 voices, and was last updated by  khoand 13 years, 8 months ago.
