  • mx5gr Friend
    #156054
    We want to add a custom block (let’s call it “slide”)between “top” and “main” positions, of the form:
    <stylesheets>
    </stylesheets>
    <block name="header" type="header" main-inner="1"></block>
    <block name="mainnav" type="mainnav" main-inner="1"></block>
    <block name="topbar" type="topbar"></block>
    </blocks>
    <block name="slide" type="module" style="xhtml">frontslide</block>
    <blocks name="middle" colwidth="30">
    <block name="left-mass-top">left_top</block>
    <block name="left1">left1</block>
    <block name="left2">left2</block>
    <block name="right2" width="41">right2</block>
    <block name="left-mass-bottom">left_bottom</block>
    </blocks>
    However, this is not feasible. Nothing appears for the “slide” block.
    Any ideas? I read http://www.joomlart.com/forums/topic/adding-custom-blockblocks-and-module-positions/ but it was not of much help…
    please follow to the wiki: http://wiki.joomlart.com/wiki/JA_T3_Framework_2/Guides#Layouts to get how adding a new position in the layout
This topic contains 2 replies, has 2 voices, and was last updated by  Saguaros 14 years, 2 months ago.
