  • VMedia Friend
    #983867
    How can I simply add a field within the Advanced Custom Module / Footer with the Uber / Gym template. as currently there is no Instagram.
    What is the php file to edit, what is the code, what line?
    Pankaj Sharma Moderator
    #983898
    You have to make changes in the acm footer style file .
    Kindly follow the suggestion given Here for the same topic .
    VMedia Friend
    #983922
    I could not get it to work in the 3-step instructions. Maybe it was because the 2nd step configure.xml file was empty and was no code to replace as instructed.
    #983968
    kindly check the file style-1.xml file inside the tmpl folder of the ACM folders .
    Here : http://prntscr.com/d41a9d
This topic contains 3 replies, has 2 voices, and was last updated by  Pankaj Sharma 8 years, 1 month ago.
