fturkmen Friend
fturkmen
- June 2011
April 18, 2014 at 5:57 am #196854alexsmirnov Friendalexsmirnov
- July 2012
- 163 times in 119 posts
April 18, 2014 at 6:17 am #531369Hi there,
If you are asking about how to place a module on top-2 position, please have a look at this comprehensive tutorial.
Hope this helps.
Alex
April 18, 2014 at 6:27 am #531372<em>@fturkmen 422336 wrote:</em><blockquote>how can i add a position to top2 that is in picture?</blockquote>
To add the module positions go to templatesja_magz/templateDetails.xml
add the position top-2
<position>top-2</position>
after the line 72 .
Hope it helps 🙂
fturkmen Friendfturkmen
- June 2011
April 18, 2014 at 6:28 am #531373for top2 there is no position that assigned. when i want to show any module on there i can’t see it on position list.
- June 2011
April 18, 2014 at 6:30 am #531374<em>@pankajsharma 422341 wrote:</em><blockquote>To add the module positions go to templatesja_magz/templateDetails.xml
after the line 72 .Hope it helps :)</blockquote>
it is ok. thank you pankajsharma
- July 2012
April 18, 2014 at 6:41 am #531377<em>@fturkmen 422342 wrote:</em><blockquote>for top2 … when i want to show any module on there i can’t see it on position list.</blockquote>
You don’t see top2 in the list of positions because the position is actually “top-2”, not “top2”.
Hope this helps.
Regards,
Alex
- July 2012
April 18, 2014 at 6:47 am #531378<em>@pankajsharma 422341 wrote:</em><blockquote>To add the module positions go to templatesja_magz/templateDetails.xml
</blockquote>
1) There is no need to create already existing position “top-2”. Please have a look at the topic starter screenshot in first post where it is clearly seen in the right hand side top corner.
2) Simply adding a custom position into templateDetails.xml doesn’t help if this new custom position doesn’t exist in the index.php.
Hope this helps.
Regards,
Alex
April 18, 2014 at 6:50 am #531380<em>@alexsmirnov 422347 wrote:</em><blockquote>1) There is no need to create already existing position “top-2”. Please have a look at the topic starter screenshot in first post where it is clearly seen in the right hand side top corner.
Hope this helps.
Regards,
Alex</blockquote>
Please check the TemplateDetails.xml file
the top-2 position was not there .hope it helps
🙂fturkmen Friendfturkmen
- June 2011
April 18, 2014 at 6:56 am #531382<em>@alexsmirnov 422346 wrote:</em><blockquote>You don’t see top2 in the list of positions because the position is actually “top-2”, not “top2”.
Hope this helps.
Regards,
Alex</blockquote>
sorry i want to write top-2, i forgot –
- June 2011
April 18, 2014 at 6:58 am #531383<em>@pankajsharma 422349 wrote:</em><blockquote>Please check the TemplateDetails.xml file
:)</blockquote>it is true that there is not top-2 position in TemplateDetails.xml file
- June 2011
April 18, 2014 at 7:09 am #531384<em>@fturkmen 422343 wrote:</em><blockquote>it is ok. thank you pankajsharma</blockquote>
but now when i add a module to top-2 position, it comes in front of mainnav..
alexsmirnov Friend
alexsmirnov
- July 2012
April 18, 2014 at 7:11 am #531386To assign position “top-2” on Joomla 3/JA Magz, simply type in by hand “top-2” (without quotes) into the “Position” field:
Your module (“Archived Articles” in my example) will be nicely placed precisely into the “top-2” position:
Once again, there is no need to touch the .xml file whatsoever.
Hope this helps,
Alex
fturkmen Friend
fturkmen
- June 2011
April 18, 2014 at 7:20 am #531387<em>@alexsmirnov 422356 wrote:</em><blockquote>@fturkmen,
Hope this helps,
Alex</blockquote>
i try to type my hand first but it doesn’t works before.. and my problem is going.
alexsmirnov Friend
alexsmirnov
- July 2012
April 18, 2014 at 7:44 am #531394Hi there,
Judging by your screenshot, you are trying to type in the “top-2” into a wrong place.
Please go to Extensions -> Module Manager:
In the list of modules find the module that you would like to place in “top-2” position and click on its name. In response to your click on your module name, the “Module Manager: <Your Module Name>” (“Banners” on my screenshot) page will open up to you:
Please have a look at the right hand side of the page and find the “Position” label and its field underneath it, in which field your should see “Type or Select a Position”. Type in “top-2”, click “Enter” and Save or Save&Close.
Now go to your site frontend, click F5 key to refresh your frontpage and test it. You should now see your module positioned inside the “top-2” position.
Hope this helps.
Regards,
Alex
fturkmen Friend
fturkmen
- June 2011
April 18, 2014 at 8:02 am #531400i found problem. i use in custom.css these codes :
.top-header {
background: #0E0E0D
border-bottom: solid 2px #EFF81B }
.ja-healineswrap em {
color: #fff
ja-headlines-item a {
color: #fff
}.top-header {height: 5px;}
when i delete , positions are ok. but i need these codes for my this thread. what can you say about this problem.
This topic contains 20 replies, has 3 voices, and was last updated by fturkmen 10 years, 6 months ago.
