  • kaisiuk Friend
    #170168
    Hi..
    I have install the Ja_zeolite and it working just fine, but i need to show more products on the site i can only show up to 8 products at a time but I need to show more. Also I am now only re-editing the sample products but I need to remove them and replace my own products I can create a product category and I can add a product in that particular category, but somehow i can’t see the new product on the site. Also if I change the currency from US Dollar to British Pound I get error. Could some one please help me. Thanks
    TomC Moderator
    #422256
    Here are a couple of resources for VirtueMart Tutorials that may prove useful . . .
    http://thecutestsiteontheblock.com/virtuemart-tutorials.html
    http://www.joomlahackers.net/virtuemart-tutorials/
    kaisiuk Friend
    #422307
    Thank You Very Much that was great help.
    Now Please I need to be able to change the top main menu BG Color. Thanks
    we2solutions Friend
    #422331
    Try this – in …css/menu/mega.css
    change
    .ja-megamenu { margin: 0; padding: 0; }
    .ja-megamenu a.over, .ja-megamenu a.active { color: #fff !important; }
    .ja-megamenu li a.active, .ja-megamenu li a.active:active, .ja-megamenu li a.active:focus {
    background:none repeat scroll 0 0 #9BAC75;
    color:#fff !important;
    .ja-megamenu li a:hover{
    background-attachment: scroll;
    background-color: #6a7947;
    background-image: none;
    background-repeat: repeat;
    background-position: 0 0;
    TomC Moderator
    #422332
    Please provide the url for the site you’re working on, and I can help identify the css you will need to modify.
    EDIT:
    Or, see if WE2Solutions’ recommendation works first. 😎
This topic contains 5 replies, has 3 voices, and was last updated by  TomC 13 years, 1 month ago.
