  • southpaw3229 Friend
    #197852
    I customized the layout so i can add a phone number and some quick links to the top right above the main nav. My issue is my customization is not responsive and on several screens it throws off the menu, plus it messes up the repsonsibe layout. Any idea on how to create a new position at the top above the main nav that is repsonsive. I know i can turn off that position on small screens, but even on desktops it throws off the main menu.
    Most websites have a small module at the top to include phone number and quick links. I would think Decor would have that but i guess not.
    fmfame Friend
    #535671
    If you want to add a new block in the layout for own position and own css please read this:
    http://t3-framework.org/documentation/bs3-layout-system#add-block
    hope it helps.
    there are many good instructions for customizing layouts
This topic contains 2 replies, has 2 voices, and was last updated by  fmfame 10 years, 7 months ago.
