  • osignite Friend
    #180767
    I am using the Ja Events template.. Joomla 2.5
    I need to add code for the use of statcounter just before the </body> tags. The instructions say this is located in the index.php file. However this templates index.php file is not the same as other templates
    What file is the <body> and <head> tags for the site located?
    I also need to add code for a live chat component in the <body> tags as well so using a 3rd party module or pasting the code to a custom html module in debug mode isn’t an option
    Thank you
    Ninja Lead Moderator
    #467631
    This is customization on T3 framework so you need check carefully when updating to the new version on the future
    <blockquote>Open plugins/system/jat3/jat3/base-themes/default/page/default.php</blockquote>
    You can see <body> and <head> on this and change anything as you wish.
This topic contains 2 replies, has 2 voices, and was last updated by  Ninja Lead 12 years, 3 months ago.
