  • andoysg Friend
    #151667
    hi. i just want to ask how to adjust margins in slideshow position – JA Ores to make picture slide in center. i want to create picture slides using mod_jaslideshow instead of mod_jaslideshow2 .please see snapshot for reference. please help. thanks
    1. ja-ores
    Dear andoysg!
    I think you should use the style of the ja slideshow 2 module from the rasite i think that your site looks nicer than.
    1) you rename the mod_jaslideshow2 folder inside the templates/ja_ores/html
    2) you dowload the the rasite template package and get the mod_jaslideshow2.css file inside the templates/ja_rasite/css folder and get some files using for the module inside the templates/ja_rasite/images . You can use filebug of the firebug to check which images you need http://www.kristarella.com/2009/02/how-to-use-firebug-for-css/
    Good luck
    andoysg Friend
    #346652
    Yes, i find it interesting. i tried it on my localhost and followed your procedure. but i did not get the same output like JA Rasite slideshow2. thumbnail did not appear and no sliding text below the big pictures and the selected article from scroll not highlight unlike from Rasite. any other css to edit? Thank you very much.
    andoysg Friend
    #346655
    sorry my mistake. i forgot to clear cache. it’s now working. thank you very much. it’s really nice 🙂
    andoysg Friend
    #346676
    hi tienhc. i copied settings of JA Slideshow2 Module from Rasite but not yet perfect. the navigation menu is having problem with alignment and has underlined title unlike from Rasite. you can see my website if you like. thank you very much.
    andoysg Friend
    #346686
    hi tienhc,
    sending you the snapshot. how can i achieve the same output as JA Rasite? thank you very much.
    1. ja_rasite
    Dear andoysg!
    Can you pls give me the link to your site
    andoysg Friend
    #346836
    sorry i forgot the link. here it is -> http://www.andoysg.com/suncity2/
    how to edit the background of scroll to make it lighter and adjust the height, etc? 🙂
    Dear andoysg!
    Please download the ja lime template package and get the file ja_lime/css/mod_jaslideshow2.css file you put it into your folder. and then you see default setting of the module on the ja lime quickstart, you ‘ll make the configuration same as so
    GOod luck
    andoysg Friend
    #347353
    hi tienhc,
    im now using the JA Rasite template to avail the slideshow2 effect and copy it exactly. i will use the light-orange color template. how can i change the background (light-yellow) into white? thank you very much.
    Dear andoysg!
    Pls open the file /templates/ja_rasite/css/colors/COLOR.css and try to find the following code as following:
    /* JA Slideshow2 —*/
    .ja-slidewrap { border: 1px solid #EEECD5; }
    .ja-slide-thumb-inner {
    background: #FBFBEF;
    border-top: 1px solid #EEECD5;
    color: #757575;
    #ja-slideshow .ja-slide-thumb img {
    background: #fff;
    .ja-slide-thumb-inner img {
    background: #fff;
    .active .ja-slide-thumb-inner img {
    background: #a06202;
    border: 1px solid #BC7400;
    .ja-vertical_right .active {
    background: url(../../images/light_orange/arrow-bg.gif) no-repeat center left;
    .ja-vertical_left .active {
    background: url(../../images/light_orange/arrow-bg2.gif) no-repeat center right;
    .ja-slide-thumbs-wrap .active .ja-slide-thumb-inner { background: url(../../images/light_orange/grad-bg.gif) repeat-x top left #a06202; }
    /* News ticker —*/
    .ja-headelines-pre { background: url(../../images/light_orange/but-pre.png) no-repeat top left; }
    .ja-headelines-next { background: url(../../images/light_orange/but-next.png) no-repeat top left; }
    /* Content slider —*/
    #ja-bot .ja-contentslider-center img {
    background: #fff;
    border: 1px solid #fff;
    you ‘ll copy those text and put into the template.css file or current color css file.
    Good luck
This topic contains 11 replies, has 2 voices, and was last updated by  Saguaros 14 years, 5 months ago.
