  • esedic Friend
    #135101
    Hi there!
    I’m using Joomla 1.5.7 and I wanted to make some modifications of the left and right columns of the Iolite template. I wanted to move left and right column a little bit to the left.
    See screenshot of what I wanted to do:
    So I did the following modifications of the template.css:
    /* COLUMNS
    #ja-colwrap {
    float: right;
    overflow: hidden;
    width: 38%; /*original 46%*/
    /*columns*/
    #ja-col1 {
    float: left;
    width: 43.9%; /*original 49.9*/
    #ja-col2 {
    float: right;
    * html #ja-col2 {
    width: 43.2%; /*original 49.2*/
    #ja-col1 div.ja-innerpad,
    #ja-col2 div.ja-innerpad {
    padding: 2px 10px 0; /*original 2px 20px 0*/
    I must admit I’m not a CSS expert, I’m mostly using trial&error method.
    So now I have sitation like this (see screenshots):
    So now I want to move dotted border more to the right and also expand content area, but I’m having problems with that. Any help would be appreciated.
    Oh, this is tested on a localhost so I can’t provide URL, but I think it’s obvisous what I want to do.
    Cheers!
    #279623
    Hi !
    To adjust position of seperator dotted , you can modify in css following instruct below :
    Open template.css file in templates/ja_iolite/css folder ,find following code at about line 482 :
    #ja-container {
    background: url(../images/vdot2.gif) repeat-y 56% 0;
    #ja-container-inner {
    background: url(../images/vdot2.gif) repeat-y 78% 0;
    you change value of red text to control position of dotted line.
This topic contains 2 replies, has 2 voices, and was last updated by  Sherlock 16 years ago.
