  • teletrance Friend
    #139269
    I will publish my article into one single column, but I have this problem: only the picture from the first article will align to left, the pictures of rest of articles are aligning top although there are align to the left in article. I know that I must change some lines in templates/tpl_opal_j15/html/com_content/frontpage and section, to look right, nut I don’t know wich line must be changed…
    Also, I need the hours when the article was publish to be shown, both in articles published in body and janews module.
    Also, the pictures are not resized, although, when I look for their properties (right-click – Properties), I get Image dimensions: 185px × 115px (scaled to 320px × 320px), but there are not! There are still shown at the original dimensions, not scalled. I know for sure that I have on my host server GD Library, is not that
    Can you please help me?
    thank you very much
    1. article-pictures-wrap-left
    2. image-properties
    teletrance Friend
    #296704
    Solved!
    In templates/tpl_opal_j15/html/com_content/frontpage/default.php, change line 41 with:
    <div class=”leading<?php echo $this->params->get(‘pageclass_sfx’); ?> clearfix”>
    the change is to that div class, from article_row to leading.
    teletrance Friend
    #296980
    I consider this thread solved and closed. How can I mark this?
This topic contains 3 replies, has 1 voice, and was last updated by  teletrance 15 years, 9 months ago.
