  • timwu1616 Friend
    #174265
    Hello there,
    I am working on JA Kranos template. I am going to select some images for the Slideshow. However, I want to change the background color of body depending on the image’s color. Can you please tell me how to do that?
    Thank you very much.
    You can change the background from this file /templates/ja_kranos/css/template.css
    body#bd {
    background: none repeat scroll 0 0 #000000;
    color: #666666;
    line-height: 1.6;
    Change the #000000; to another Hex value
    timwu1616 Friend
    #439951
    <em>@pavit 302732 wrote:</em><blockquote>Hi
    body#bd {
    color: #666666;
    line-height: 1.6;
    Change the #000000; to another Hex value</blockquote>
    Hi pavit,
    Thanks for reply.
    That’s right, I’ve found where to change the color. But, is it possible to change it dynamically based on the some condition because I want the color to be different based on the images?
    I think that you need some php script to manage this new feature
    try to search for some free resource as background rotator
    timwu1616 Friend
    #439953
    <em>@pavit 302748 wrote:</em><blockquote>Hi
    Regards</blockquote>
    Yes, I believe so. Can you please show some hints for what the idea is to do this?
    Thanks.
    Try to look at this
    or try on JED here
    cianouno Friend
    #446868
    Hi Pavit,
    great solution for background color, but if i wanto put an images as bg insted?
    The code could to be this?:
    body#bd {
    background: none repeat scroll img src="../images/bgimage.jpg";
    Thank you very much
    Enrico .
    body#bd {
    color: #666666;
    line-height: 1.6;
    Hi cianouno
    You can use also
    body#bd {
    background: url("../images/yourimage.xxx") repeat-x scroll left top #ffffff;
    anyway it depends on how you want manage the background
    cianouno Friend
    #447052
    Hi Pavit,
    so if i set the code as you say me, the bg change with image… let me try it, and after report here result.
    The modify is same for all kind of template? I say this because a try to use Kranos template (see this url http://homecinema.homepc.it/dimsea), and now itry your solution for background….
    See u soon
    Enrico
This topic contains 9 replies, has 3 voices, and was last updated by  cianouno 12 years, 8 months ago.
