June 12, 2012 at 2:03 am #178045
the mainreason i renew my membership was the rpxplugin. I was sure, that the Joomlart is better then other….
Now i cannot see where to configure anything. I don´t want my users login via Yahoo, AOL or Open ID. I want to have Facebook, Twitter and Google to login, the rest doesn´t matter in Germany.
And when i try to login via Google or Yaho, it shows me “Invalid Parameter: token_url domain not in whitelist”
The login is only in JaComment. Just scroll down. http://www.fotoblogazin.de/home-fotonews-a-rumors/fotoequipment-allgemein/objektive-fremdhersteller/572-samyang-8mm-f28-fischauge-nex-nx
Can somebody explain me, how i can configure it and solve the problems?
Sherlock FriendSherlock
- 2478 times in 2162 posts
June 13, 2012 at 9:38 am #457227hi caspa0202,
Thank you for loving this plugin 🙂
Firstly when using this plugin you might already registered and have a Janrain account, if not yet you can signup an account here https://rpxnow.com, after signing up you go to the Ja janrain plugin back-end to make a proper settings follow the guide here http://wiki.joomlart.com/wiki/JA_Comment/Administration
<blockquote> Now i cannot see where to configure anything. I don´t want my users login via Yahoo, AOL or Open ID. I want to have Facebook, Twitter and Google to login, the rest doesn´t matter in Germany.</blockquote>After sign up an account at https://rpxnow.com/ you can login with your account and in the account setting you would be able to choose a provider (facebook, yahoo..) whether or not showing
<blockquote>And when i try to login via Google or Yaho, it shows me “Invalid Parameter: token_url domain not in whitelist” </blockquote>
In your account setting at https://rpxnow.com/ you navigate to Deployment >> Application settings there it has a field name Domain Whitelist and you would need to enter your domain there.I hope you can make a proper setting by yourself 🙂
1 user says Thank You to Sherlock for this useful post
June 13, 2012 at 4:04 pm #457263Thank you.
I followed the instructions, but now it shows: “Server under OpenID could not be found”. Maybe it takes a time until it performs well? :((– I made an rpxnow account
– Creates applications for Twitter, Facebook and Google
– Put my page on the white list
– Configured the sign-in
– Add the adress and ID to my Joomla pluginDo i forget anything?
June 14, 2012 at 6:59 am #457354<em>@caspa0202 325181 wrote:</em><blockquote>Thank you.
– Add the adress and ID to my Joomla pluginDo i forget anything?</blockquote>
Which Rpx Application you added to the plugin ? I think you can try to leave this field empty with only Rpx ApiKey is fine.
If that does not help you can pm me the Rpx ApiKey and I shall check it for you.
June 15, 2012 at 4:49 pm #457621Thank you very much for your help.
I made the mistake to copy the API Key into Janrain without deleting the whitespace.Then Google, Twitter and Flickr login worked well then, except Facebook:
<blockquote>{
“error”: {
“message”: “Invalid redirect_uri: Given URL is not allowed by the Application configuration.”,
“type”: “OAuthException”,
“code”: 191
}</blockquote>I think i forgot to adding my website to the Facebook-application. But after i changed it, none of the four Login´s worked. Everyone shows <blockquote>The token URL or xdReceiver has not been whitelisted</blockquote>
But i already have whitelistet my site and it worked well before.
June 15, 2012 at 7:32 pm #457632UPDATE
The problem with the whitelist das been solved, but when i login with Twitter, Google or Flickr it doesn´t login and show “login” again…. The problem with Facebook hasn´t been solved too.Sherlock FriendSherlock
June 18, 2012 at 3:35 am #457728Hi caspa0202,
Have you disabled using JA Janrain ? I took a look but did not see the box appeared, You can pm me your admin account and the API Key if possible, I may need further checking on this.
June 18, 2012 at 4:11 pm #457884Your message-box is full^^
June 19, 2012 at 1:49 pm #458026<em>@caspa0202 325992 wrote:</em><blockquote>Your message-box is full^^</blockquote>
Tried to login to your back-end and facing this error
[PHP]Fatal error: Class ‘JController’ not found in /homepages/11/d364340627/htdocs/fotoblogazin/administrator/components/com_login/login.php on line 23[/PHP]have you faced it ?
June 21, 2012 at 7:42 am #458301The biggest problem is solved. In the plugin “register new user” must be acitivated.
Only Facebook allready doesn´t work well.
June 21, 2012 at 9:33 am #458315Thank you very much for your help. It´s solved, Everything works fine 🙂
June 21, 2012 at 10:05 am #458324<em>@caspa0202 326540 wrote:</em><blockquote>Thank you very much for your help. It´s solved, Everything works fine :-)</blockquote>
Glad to hear that, Can you let me know what is the facebook problem ?
June 21, 2012 at 11:30 pm #458390<em>@Sherlock Holmes 326549 wrote:</em><blockquote>Glad to hear that, Can you let me know what is the facebook problem ?</blockquote>
After i made a new Facebook-Api for Janrain, i have forgotten to include my webpage in the right field.
I have had to sleep more then 4 hours to see that^^ -
This topic contains 13 replies, has 2 voices, and was last updated by caspa0202 12 years, 7 months ago.
