gwahlers Friend
gwahlers
- November 2014
November 28, 2014 at 8:08 am #203130Hi There!
I use the purity III template.
How can i configure my megamenu:- for desktop view the hover-menu-trigger
- for mobile view the click-menu-trigger
In my template configuration i always see two ways but no mix of them.
I wish i could see a thrid option: “click-menu for mobile and hover-menu for desktop”.
Greetings!
Eragon H FriendEragon H
- July 2014
- 156 times in 149 posts
December 1, 2014 at 2:42 am #557103Hi gwahlers,
The T3 framework current doesn’t support this option “click-menu for mobile and hover-menu for desktop”.
Best regards,
Eragon H
gwahlers Friendgwahlers
- November 2014
December 1, 2014 at 8:16 am #557158Say never no! 🙂
I solved this Problem with a second Installation with the purity III template.
1. Download a second copy of the template-archive.
2. Rename the template-name in tempaltedetails.xml in purityIII_mobile
3. Save the .zip-file.
4. Install “edited” Template.
5. Get the Mobile Detector out of JED.
6. Activiate the plugin and switch in case of mobile views to the purityIII_mobile template.
7. Edit the purityIII_mobile template for mobile devices.
Greetings Gwahlers1 user says Thank You to gwahlers for this useful post
AuthorPostsViewing 3 posts - 1 through 3 (of 3 total)This topic contains 3 replies, has 2 voices, and was last updated by gwahlers 10 years, 1 month ago.
How to configure menu click-trigger for mobile and hover-trigger for desktop view
