  • amit_s_r Friend
    #169893
    My site url is http://www.freeaffiliateassistant.com/ ,Joomla version version is 1.5
    And the theme is JA_EVENTS
    I want to ask you how to create menu on both sides,
    Pls pls help me…
    jooservices Friend
    #420642
    I have a little bit confuse. could you please explain more detail ? also please take a snap shoot and point out the place where the menu you want to create.
    Viet Vu.
    amit_s_r Friend
    #420643
    I want menu on both the sides i.e right and left only on members area tab ,i am send u the screenshot from that you can understand very well.
    Thanks for the reply…
    1. screenshot
    amit_s_r Friend
    #420828
    i have send the screen shot and detail please check it…
    Thank you helping….
    jooservices Friend
    #421087
    By check these positions: http://templates.joomlart.com/ja_events/?tp=1
    I don’t think left position as you expected is included in template. To do that you’ll need update xml / css also 🙂
    Thank you
    Viet Vu
This topic contains 5 replies, has 2 voices, and was last updated by  jooservices 13 years, 2 months ago.
