  • billiec Friend
    #207573
    Is it possible to create an alpha index in this directory theme (1st letter of items) such as the one that ZOO uses in it’s business directory…. that is A B C D E F G etc linking to first letter of items.
    Or, do you know of an extension that will do this so that I can use it in your theme?
    Pankaj Sharma Moderator
    #574692
    Hello
    can u explain a bit more in details , what exactly you needed , if possible provide an example .
    #641036
    Hello
    #739700
    Hello
    billiec Friend
    #574815
    Here is zoo example:
    http://yootheme.com/zoo/apps/index.php?option=com_zoo&view=frontpage&Itemid=5
    I am looking for a way to create the a-z module across the top that links to items by 1st letter in company name… which would be the first word in the title of the K2 item.
    Also used by SOBI Pro:
    http://demo.sobi.pro/joomla-business-directory/
    #574821
    sorry but currently template does not have any function like you needed .
    while you can search third party extension on Joomla Extension directory.
This topic contains 6 replies, has 2 voices, and was last updated by  Pankaj Sharma 9 years, 5 months ago.
