March 27, 2009 at 10:47 am #139640
Question is simple… how to create new module place for search module above VM-fp place/position (mod_virtuemart_featureprod )?
Something like this: http://www.mojaakcija.hr
and need to be here http://www.racunala-akcija.com
hanifahmed Friendhanifahmed
- August 2008
- 141 times in 110 posts
March 27, 2009 at 11:10 am #298438Wait i’ll try right now…
March 27, 2009 at 11:12 am #298439Ok, that is it but i need more attractive that search module and a liitle moved from vm-fp
look now in http://www.racunala-akcija.com
March 27, 2009 at 11:16 am #298441I mean where i can edit width and height of search module and how to increase height of border of module (just for 5pix)
- August 2008
March 27, 2009 at 11:21 am #298445Try inserting a custom module with a few blank lines underneath that to seperate it out.
Module Manager -> New (at the top) -> Custom HTML ->Go to the WYSIWYG editor at the bottom, press enter once and set the position as vm-fp and under search but over FP. It MIGHT work
March 27, 2009 at 11:27 am #298446Ok, let’s say that is ok. And how to make search field more attractive (bigger, wider…)
(thx for your help) 🙂
- August 2008
March 27, 2009 at 12:30 pm #298459You can change the box width in Module Manager -> Search under Module Parameters.
You can make additional changes by changing the file mod_search.php which you can find in /modules/mod_search.
Make sure to make a backup copy before you make any changes to any files so you can fix any problems instantly.
1 user says Thank You to hanifahmed for this useful post
March 27, 2009 at 12:34 pm #298461Ok, thx for your help. Solved 🙂
- August 2008
March 27, 2009 at 12:41 pm #298464Why not show the title of the image, it’ll make it look better! Give it a name like “Search for your product” and click on Show Title and Apply and see if it looks any better!
Looks sort of misplaced as it is – especially with the big gap.
March 27, 2009 at 12:49 pm #298468Hm, I am not sure how to give a name like “Search for your product”. I mean, where?
- August 2008
March 27, 2009 at 12:56 pm #298471In Module Manager, click on the Search Module, and under Module Title, change the name to what you want it to appear as. Then click on show title: yes: and press apply and check how it looks!
March 27, 2009 at 1:57 pm #298483Well, it is ok bud somehow it is not clear… maybe to align to center? How to do that?
AuthorPostsViewing 13 posts - 1 through 13 (of 13 total)This topic contains 13 replies, has 2 voices, and was last updated by dgosijek 15 years, 6 months ago.
How to create place for search module above VM-fp
