missyw Friend
missyw
- May 2008
- 2 times in 1 posts
December 16, 2011 at 8:04 am #171861I have added Virtuemart to this template, and it has a shopping cart module which displays in the right position like so:
I would really like to have a simplified version of this showing in the header, as it does in ja-zeolite:
How do I do this?
My first problem is, I think, to add a new module position in the top.header area of ja-droid. I have tried to do this, but am having troubles:((. I tried:
1. adding the following line of code beneath “top” position in templateDetails.xml<position>top-cart</position>
2. adding the following line of code to templates default.xml (beneath block-name=”header”)<block name="top-cart" type="modules">top-cart</block>
– but this results in a new position BELOW top.header, whereas I want it to be in the right within the top.header block.
If I can manage to create the module position, then I will still need to be able to format the shopping cart module to look like the one in ja-zeolite, if that is possible? How do I do it?
TomC Moderator
TomC
- October 2014
- 3155 times in 2495 posts
December 16, 2011 at 5:15 pm #429996In order to try to best assist you, please provide the url of the site you’re working on
– as well as set temporarily set “Optimize CSS” to “No” within your Template Manager–General Settings -
Viewing 2 posts - 1 through 2 (of 2 total)This topic contains 2 replies, has 2 voices, and was last updated by TomC 12 years, 11 months ago.
