  • madfish2008 Friend
    #134399
    Hi!
    I would like to know how to display products without names in mod_virtuemart_featured.
    The reason for that is i have too long names for products.
    Thank you for help 🙂
    shertmann Friend
    #275274
    well if you do not want to edit the code which one is one option then you must edit the products name and set a blank space instead of the product name
    shertmann Friend
    #275275
    other option can be assign the product a short related version of the name
    madfish2008 Friend
    #275392
    Hi!
    No problem to edit the code, but where and how …
    Can someone help that point ???
    i only want to display facebook in featured products.
    :confused:
    madfish2008 Friend
    #275403
    Solved it myself … in fact, i was trying to edit the wrong file.
    so to display only pics of products :
    go to … /components/com_virtuemart/themes/ja-mesolite/templates/common
    open productsnapshot.tpl.php
    in line 3
    <span style=”font-weight:bold;”><?php echo $product_name ?></span>
    delete or put between <!– xxxxx –>
    shertmann Friend
    #275744
    good job madfish
This topic contains 6 replies, has 2 voices, and was last updated by  shertmann 16 years, 2 months ago.
